DOUT Related Questions
I have two questions related to the Midibox CV DOUT gate/trigger-related code available here:
http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_midibox_cv_with_a_dout
  1. Right now the code responds only to a single midi channel.  How could I change it to respond to ALL midi channels?
  2. Instructions are given to conform the DOUT gates to 1ms triggers to use with drum modules (which is my purpose.)  However, some of my modules respond to gates, not triggers (the CGS Cynare’s Sustain input.)  How could I modify this code to exclude specific DOUT pins from the 1ms-reset?
Thanks for any help. :)  I am trying to learn ASM, but the syntax is very foreign to me.  Looking forward to C-based programming with the new core!!
Lars
Following lines:
movlw	0x90 ; check for Note On at channel #1
cpfseq MIOS_PARAMETER1, ACCESS
rgoto USER_MPROC_NRE_NoNoteChn1
[/code]
have to be replaced by:
[code]
        movf    MIOS\_PARAMETER1, W   ; get status byte
        andlw    0xf0                           ; mask out MIDI channel
        xorlw    0x90                           ; check for Note On
 bnz       USER\_MPROC\_NRE\_NoNoteChn1   ; skip if not a Note On event (ignore wrong label name)
  1. Instructions are given to conform the DOUT gates to 1ms triggers to use with drum modules (which is my purpose.)  However, some of my modules respond to gates, not triggers (the CGS Cynare’s Sustain input.)  How could I modify this code to exclude specific DOUT pins from the 1ms-reset?
Replace:
USER_SR_Service_Finish
clrf    MIOS_PARAMETER1
movlw   0x00
call    MIOS_DOUT_SRSet
movlw   0x01
movlw   0x02
movlw   0x03
[/code]
by:
[code]
USER\_SR\_Service\_Finish
 movlw   0x00
 call    MIOS\_DOUT\_SRGet
 movlw 0x00        ; (\*1)
 andwf MIOS\_PARAMETER1, F
 movlw 0x00
 call    MIOS\_DOUT\_SRSet
 movlw   0x01
 movlw 0x00        ; (\*2)
 movlw 0x01
 movlw   0x02
 movlw 0x00        ; (\*3)
 movlw 0x02
 movlw   0x03
 movlw 0x00        ; (\*4)
 movlw 0x03
 movlw   0x04
 movlw 0x00        ; (\*5)
 movlw 0x04
(*1) .. (*5): instead of 0x00, you have to set an AND mask which matches with your requirements.
E.g., if the rightmost DOUT of the second SR shouldn’t be cleared after 1 mS, use “movlw 0x01” instead of “movlw 0x00”
if two rightmost DOUT of the second SR shouldn’t be cleared after 1 mS, use “movlw 0x03” instead of “movlw 0x00”
if only the leftmost DOUT of the second SR shouldn’t be cleared after 1 mS, use “movlw 0x80” instead of “movlw 0x00”
etc.
Wonderful, thank you!!!
I’d like (just for ease-of-setup purposes) to be able to have a table that will assign specific MIDI notes to specific DOUT pins, in case I want to change things up after I get everything wired up.  (This is a custom Midibox CV application for a modular drum machine with over 30 drum voices.)  But I will save that for when I can learn a bit more of the syntax, since it seems fairly straightforward. :slight_smile:
I’m experiencing a problem with the trigger outs –
Is there anything about this code (on the Wiki page) that might send only the first 8 notes to all DOUTs?
For example, my problem is that Note C-1 is triggering SR1 Pin 1 and SR2 Pin 1, Note C#1 is triggering SR2 Pin 2 and SR2 Pin 2, etc.
I’ve checked my DOUT wiring and serial ins/outs between the pins of the 595s and everything is connected correctly.
Yeh…
movf	MIOS_PARAMETER2, W ; pin number: note number - 0x24, we start with C-2
	addlw	-0x24
Maybe you could do with some checking in there, to deal with what should happen when the note received, is lower than C2…
hmm, i will check into that.
just a dumb newbie check – is there anything I need to define in the code to let MIOS know how many shift registers are in the DOUT chain?
Okay, for my own edification I’ve attempted to thoroughly comment each step of the code.  I referred to the 18F452 datasheet to try to deduce the different instructions syntax.  I also renamed some of the functions and now the DOUT pin number = MIDI note number.  Can you guys let me know if I’m on the right track here?  I had to guess in a couple places (couldn’t find skpz in the datasheet.)  I also commented out the call to CV_MIDI because my current application uses DOUT only.  (I’d eventually like to modify this to translate velocity information to AOUT for specific drum triggers.)  This code compiles without errors.
USER_MPROC_NotifyReceivedEvent
	;; BEGIN --- control DOUT pins via Note events at all channels
	movf	MIOS_PARAMETER1, W ;; get MIDI event type & channel number
	andlw	0xf0 ;; ignore non-valid MIDI events & channels
	xorlw	0x80 ;; check for Note Off
	bnz	USER_MPROC_NRE_NotNoteOff	;; skip if not a Note Off event
USER_MPROC_NRE_NoteOff ;; if the event is Note Off
	bsf	MIOS_PARAMETER1, 4 ;; midi event type changed to Note On
	clrf	MIOS_PARAMETER3 ;; set velocity = 0
        xorlw    0x90                          ;; check for Note On
	bnz      USER_MPROC_NRE_NotNote ;; skip if not a Note On event
USER_MPROC_NRE_IsNote
	movf	MIOS_PARAMETER3, W ;; get MIDI velocity information
	skpz ;; skip next instruction if velocity = 0
	movlw	0x01 ;; set W = 1
	movwf	MIOS_PARAMETER1 ;; set MIOS_PARAMETER1 = W
	movf	MIOS_PARAMETER2, W ;; get MIDI note value
	andlw	0x7f ;; ignore non-valid note values
	call	MIOS_DOUT_PinSet ;; pin = note number, value = MIOS_PARAMETER1
	;; END --- control DOUT pins via Note events at all channels
	;; process MIDI event
	;; call	CV_MIDI_NotifyReceivedEvent
	;; for best latency: branch to USER_Tick so that the new CV values
	;; will be mapped immediately
	rgoto	USER_Tick
Greetings..
I regret that I don’t have time to thoroughly answer your questions..
But I can toss you a quick answer..
Somewhere in the mios source tree is a file called macros.h
On this machine the end of the path is MIOS\mios_base_v1_0b\include\asm\macros.h
(OK, so I probably have an old version..)
This file defines a variety of useful macros, including skpz
#define skpz btfss STATUS,Z
It’s worth reading the file to see what else has been done for you.
Have Fun,
LyleHaze
Thanks very much for the info, I’ll check that out.
I tested the above code and it works, except I’m still having the same problem with the DOUTs as described above.  I am guessing I’m missing something somewhere, where I need to tell MIOS how many shift registers are connected… or maybe there’s still something I overlooked with the shift register connections.  I tried new 595s and that didn’t help.  I’ll do some more double-checking tonight.  Any help is appreciated!
Resolved!
The following code in main.inc had to be changed to reflect the number of shift registers connected:
;; initialize the SRIO driver
	movlw	0x01
	call	MIOS_SRIO_NumberSet
This worked for me:
	movlw	0x0F
I’ll update the wiki.  Thanks for all the help!
