i connected the master to the front panel like that :
menu -> first DIN J3
Button 1 to 4 -> first DIN J4
Button 5 to 8 -> first DIN J7
Button 9 to 12 -> first DIN J6
Button 13 to 15 -> first DIN J5
When i startup the core, the 5th note on the screen is always ON …
I push the 5th button and release it : the 5th note disapear … but i push on button 1, 2, 3 or 4, the 5th note comes ON again and stays like that … ???
I also notice that the buttons 1 to 4 and 9 to 15 gives a C2 note on the screen but the buttons 5 to 8 gives a C5 note …???
first : problem solved … it was a multiplexer which was crazy .. i changed it … it works fine now !
second : TK : because i have another problem concerning the config and the soft …
i just want to know first if i choosed the right dispatching of different faders, boutons and encoders regarding the 2 core …
My way to work with Propellerhead Reason is :
i make a song with one 14 channels mixer and the next song in my set with another mixer … And i want to pass from one mixer to the next one just by changing the bank …
I know that i have to use the banks to switch and the SFB to send (from the master core: id0) the Bank change to the slave core (id1) …
So i just need to know if i am right in my config …
the bank changes on core 1 are transmitted to the sec. core ?
if you’ve enabled “Send Program Change on Bank Changes”, yes
At the receiver site “Receive Program Change for Bank Change” should be enabled.
Or do i have to change some code lines ?
no, you can do this change in your .ini file, or with Serge’s Editor
I mean : i understand what is in the control messages generated by the menu navigation … (Display, bank changes … ) but do i have to change something in the code of the receiver cores ?
the diagram above shows a concept which can be used by other programmers if they want to control multiple midiboxes from a single control surface. This is not implemented in MIDIbox64. If you need this, then you have to program this by yourself.
Did you allready write some code for other applications ?
yes, but totally unsupported, since it’s unfinished and I don’t plan to add more into this direction since the implementation is very hardware specific (in other words: I don’t want to program individual solutions for you guys which I would never use by myself…)
Check the MIDIbox64 SysEx Implementation doc, search for MIDI remote, and think about the possibility to send these sysex commands via meta events…
