Does MIOS/MIDIBox64 Require Bankstick?
I’m at the point where I’m testing my MB64 and I have a few questions, including the main one in the title:
  1. I bought my PIC from SmashTV. I believe it has the bootstrap loader burned into it already. There’s a sticker on it stating it
s bootstrap loader v1.1b and has ID 0 etc… from my understand I believe this means I just need to load the MIOS operating system and then load the MB64 program.
  1. A followup to the question above. Do I need to load MIOS v1.8 before loading the MB64 v2.4 application or does the MB64 v2.4 application include everything already?
3 I can’t figure out  if MIOS requires a Bankstick. The whole time I was building my MB64 I was thinking the PIC had all the required memory on board for one program. Can someone please explain or let me know if MIOS/MB64 requires a banksitck?
Thanks in advance.
Brian.
Hey Brian
… this is correct
… yes, you need to load MIOS first
… the PIC has the required memory available. A Bankstick you needonly, if you’d like to switch between different configuration setups (banks)
Greets, Roger
great. Thanks for the quick response!
Brian
