Does Midibox SEQ V3 support triplet?
Does Midibox SEQ V3 support triplet so it uses 6 steps per 4/4 beat?
couldnt find any clear answers about that with search function.
thx for help
No, this isn’t possible yet, but could be easily added by enhancing the clock divider function.
I will add this to the wishlist
I’ve added the code for triplets - the implementation of the feature itself was quite easy, but it was difficult to overwork the menu layout so that the new mode can be selected in an intuitive way - however, I think that I found a good solution (now different timebases are available at the right side, like 8, 8T, 16, 16T, …)
The feature + user manual update will be available with the next release (it’s already available on request, but I haven’t tested if the rest is still working…)
Thanks TK!! Triplets are a must-have for me. :slight_smile:
thank you for the fast implementation of triplet to the sequencer.
i will test it in the next time. because i am a little bit busy.
regards
ruff-g
