Spectrasymbol has developped new XY-Pads which work like 2 independent Pots. They are also supposed to act like a pot. This means that the value doesn’t go to zero when you don’t touch the pad.
Count me in for XY Pads and any of their softpots…
I’ve only got one sample of their softpot… eventually I’m going to make a MIDIbox ribbon controller and eventually was going to arrange a bulk order if enough people wanted to make their own. But that’s a long way off…
Nah spectra were lame about samples. They handed out a few, but quickly cut back when we hit hem too hard Only a handful of the dozens of people around here actually got the sample they asked for.
Count me in for some XY/ribbon/pot goodies though…
That’s because people around here who ask for samples aren’t really the intended audience. Samples are supposed to go to those who literally want a sample, to possible use a lot more in the future. They aren’t intended to be handouts for those who are too cheap to buy their own.
I gotta XY pad from SS but still don’t have any FFC connector to plug it to. Don’t forget to get one if you ever want to use that sensor with your midibox project
If you look at the pad, you’ll see that there’s no pin that you can solder directly.
The output of the XY pad is some kind of flat cable with 4 tracks, and you absolutely need a FFC with 4 inputs to plug on the connector. One side of the connector is FFC, on the other side you have “normal” metallic pins where you can solder … to your AIN
I asked for any companies in germany that sell spectraSymbol stuff, but the thing is: most spectraSymbol products get produced on demand based on custom specs (like PCBs); so with most orders there are 1000 EUR gone for “making the production masters”… but I’ve been told they are about to produce some standards for users like us, it sounds like this is happening right now
I can take a look in my bookmarks if this XY-Pad ordering will fail for any reason (which I do not hope! ;D )
