Yesterday my Midicable got broken…dunno why, it dosnt send or receive anything >:( checked it with my multimeter, but only the ground pins make a beep…
so I build one myself like described here :
15-pin SUB-D 5-pin DIN
(Pins in front-sight of the Plugs)
1 8 2
o o o o o o o o o
o o o o o o o 5 o o 4
9 15 3 o o 1
MIDI-In Pins :MIDI-Out Pins :
SUB-D DIN SUB-D DIN
4 -> 2 8 -> 4
8 -> 4 12 -> 5
15 -> 5
Now I tested to upload some code with my self-soldered cable to my MB but it dosnt…MIOSStudio receives midisignals when I turn pots/encoders but the uploads dosnt run
Now my Question :
Do I need make a optocoupled Cable like in the schematic here ?
I’m lost in this kinda thing but the “done thing” seems to be a 7404… Maybe these will help. Maybe they will totally balls the whole thing up ;D
Joystick Adapter NOTES:
A good choice for the Optoisolator 6N137. A 6N138 will work, but is slower.
Resistors are 5%
Inverter A can be an IC or a transistor.
It is extremely important not to ground pin 2 of the MIDI IN connector. A noise-causing ground loop will result if you do. Pin 2 of the MIDI OUT connector should be grounded. That way the shield of the MIDI cable will be grounded on one end as desired.
