Hi Rob,
First question : where i take trigger signals for instruments? (the 16 step-leds are also triggers out?)
Have a look into the setup_mb808_default.asm file (which is also referenced by setup_808_with_swingpot.asm)
; Following table allows you to define
; - the track names (must consist of exactly 6 characters!)
; - the DOUT shift registers (SR) to which the drum triggers are connected
; (1-16; 0 disables assignment)
; - the DOUT pin to which the drum triggers are connected (0-7)
; Note: since version v1.3 the "real" Dx pin number (D0..D7) has to be specified, in previous releases it was mirrored!
; - the MIDI output port (0=disabled, 1=Default, 2=Internal, 3=IIC1, 4=IIC2, 5=IIC3, 6=IIC4, 7=Trigger Only)
; - the AOUT/CV channel to output velocity (1-16, 0=disabled)
; Note: AOUT module only supports 8 highres channels, but CV outputs can also be realized with DOUTs (see DEFAULT_CV_DOUT* option)
DEFAULT_TRKINFO MACRO
;; Name SR Pin MPort AChn
db "BD ", 1, 6, 1, 0 ; Track 1
db "SD ", 1, 5, 1, 0 ; Track 2
db "LT/LC ", 1, 4, 1, 0 ; Track 3
db "MT/MC ", 1, 3, 1, 0 ; Track 4
db "HT/HC ", 1, 2, 1, 0 ; Track 5
db "CP ", 1, 1, 1, 0 ; Track 6
db "MA ", 1, 0, 1, 0 ; Track 7
db "RS/CL ", 4, 7, 1, 0 ; Track 8
db "CB ", 4, 6, 1, 0 ; Track 9
db "CY ", 4, 4, 1, 0 ; Track 10
db "OH ", 4, 3, 1, 0 ; Track 11
db "CH ", 4, 2, 1, 0 ; Track 12
db "Ext1 ", 0, 0, 1, 0 ; Track 13
db "Ext2 ", 0, 0, 1, 0 ; Track 14
db "Ext3 ", 0, 0, 1, 0 ; Track 15
db "Acc. ", 7, 0, 7, 0 ; Track 16
ENDM
this is also the place, where you could change the pinning - the .asm file has to be recompiled to a new .hex with the MIOS8 toolchain as described here: http://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_quickstart
Second question : i think i’ve flashed the wrong firmware version for my hardware what are the differences about versions in
“midibox_808_v1_3a†pack? someone have a correct pin list for dout pins with “setup_808_with_swingpot†and showtech modules?
the complete configuration is described (and can be customized) in the .asm files
