Hi, I found this today…
it looks really good for the most purposes. Better than a soundcard scope.
http://jonw0224.tripod.com/ppmscope.html
Specifications and Goal Feature List:
Feature
Current Version (v.2.01)
Goal Version
Sample Rate
Variable, single shot 1 MHz max, interlaced 151 kHz max
Variable, single shot max 1 MHz, interlaced max 417 kHz, repetitive 5 MHz
Bandwidth
500 kHz
500 kHz
Number of Channels
Two
Two
Sample Depth
256 bytes per channel, 128 bytes per channel when interlaced
Sample Modes
Single shot and interlaced
Single shot, interlaced channel, and repetitive
Calibration
Voltage offset
Voltage per division and voltage offset calibration
Configuration Settings
Configuration of default and saving of settings for future use
Hardware Connection
Any parallel port
Any parallel, serial, or USB port
Coupling
AC and DC, reflected on PC
Channel gain
Gain of 1, 2, and 5, reflected on PC
Trigger
Variable level, slope, and timing
Frequency Spectrum
Yes
Yes
Waveform Reconstruction
Triangle, square, point, and sinc
XY view
Yes
Yes
Channel offset and volt per division settings
Yes
Yes
Cursors
Yes
Yes
Math functions
Only addition and subtraction of channels
Addition, subtraction, auto period, auto peak-to-peak, etc.
Waveform export
Comma delimited
Bitmap and comma delimited
I’ll build one ![]()
bye
