Dinx4 PCB layout
Hello all,
I’ve been looking for a link for SmashTv’s New version of the Dinx4 layout in eagle format.
I know he’s pretty busy,  So I was planning etching a couple myself.  I tried the wiki on ucapps but
those links seem to fail.  ???
Thanks
Villadon
I may be incorrect (and please correct me if I am), but I don’t think SmashTV publishes the eagle layouts for his boards. He usually makes a GIF image available on his website but not the corresponding eagle file.
You can always make the current DIN version from the file available on ucapps, but if you want Smash’s version you’re probably better off just buying the bare PCB from him and populating it yourself.
-drin
Yes,
For Various Reasons Smash doesn’t make his board layouts publicly available.
Moebius
Thanks Guys
Wasn’t sure if he did or not.  I bought (4) of the R2 versions a while back and I hated crimping (Could never get it right).  So I figured I’d use the new layout
and use the IDC connectors instead.  His store has been closed for some weeks now and I was just going to order again (can’t beat his prices  ;)).  What I was
really planning out was to make a couple on a large clad and tie them all together. Maybe I’ll just play around with the R2 version and incorporate the new dual
row headers somehow since I have a Din that is not soldered yet.  Hope he wouldn’t mind.
Thanks again.
Villadon
What I was really planning out was to make a couple on a large clad and tie them all together. Maybe I’ll just play around with the R2 version and incorporate the new dual row headers somehow since I have a Din that is not soldered yet.  Hope
he wouldn’t mind.
I can’t speak for Smash, but I suspect he won’t have any objections (Tim? Is this where I get flamed? :)).
As a suggestion, it might be a good idea to document your rerouting and add it to the Wiki for others who decide to take R2 boards and put DIL headers on them instead of the current SIL. I’m pretty tired of soldering wires and shrinkwrap on them myself. :slight_smile:
-drin
Thanks drin,
I’ll be sure to post on the wiki after i test the first board.
villadon
