I have checked DINX4/DOUTX4 modules twice with multimeter, not any shortcut, but my control panel doesn’t really works.
First thing, the synthesizer part seams work well (Just the output 3 and 4 with no sound, but it is another problem…).
I checked and re-checked the control panel four times…
I tried to invert some 74HC165, but with no differences.
The first 74HC165 works, the others not, and two buttons seams be inverted…
I suppose that DINX4 problems cause DOUTX4 problems too?
In attachement you have a view of the dinx4 chematics with notes…
I have tested the CORE J8/J9 pins with the srio_interconnection_test_v1b program and I have discovered that the pin J9/S1 doesn’t change of state, the voltage is always 5.0 V.
In attachement you have a view of the CORE J8/J9 pins checked with my logic analyzer…
As you can see, the J9/S1 pin stay high all the long…
I am not an expert, but I think the problem comes from the CORE module…
I checked the CORE module, but I found not any shortcut.
