DINX4 assembly (back)
Hello,
Quick question:
I can’t figure out how to assemble the back of the DIN4X…
Suppose to add 4 jumper wires and 4 caps but the pictures in the tutorial are too shady and Im too much a noob to do it without.
Does anyone have a picture of the back of a DIN4X?
If it can help I can upload a picture of my attempt, maybe somebody can point out where I went wrong
KEEP YOUR SOlDERING IRON HOT! =)
Which version of the board are you using? From Mike’s or from SmashTV’s (the latter one has a version number on it)?
Version 2
DINX4
From Mikes Midizeite
There is like a landingstrip/surface soldering on the back, I attached the jumperwires on those
But if somebody has a picture it will clear up my mind, Ill take pictures in a minute
Here
I soldered them all the same
Can you tell me if this is correct?
bump
Looks good
