Hello to all,
Finally i’m starting to build my MIDIbox SID Control Surface ver.
I’m getting troubles on understanding the DIN soldering and wiring work.
On DIN pagehttp://ucapps.de/mbhp_din.html we could read on ‘Used Components’ chapter that:
These pull-up resistors are required if buttons are connected to the digital inputs.
(talking about the 10k resistors).
Does it mean i don’t have to put resistors where i’ll connect the encoders on DINx4 boards?
Into the connection diagram http://ucapps.de/midibox_sid_cs/mbsid_din_default.pdf i couldn’t see where resistors are and where aren’t… instead of http://ucapps.de/midibox_sid_cs/mbsid_dout_default.pdf diagram which has resistors drawned.
Again on http://ucapps.de/midibox_sid_cs/mbsid_din_default.pdf: the last board on right side is a DIN, does it have only one 74HC165 shift register? ???
If so, what i have to do with the others three 74HC165s banks? (i have only DINx4 boards)
I must put bridges or resistors(which?) between each last 3 shift registers’ pinouts? ???
Just a comment: on diagrams .pdfs couldn’t be usefull a legend that clarify which symbols mean buttons, which mean encoders, etc.??
I hope to be understandable
Thanks all of you ppl out there
Gord The Rogue
