din problem
hi all,
i have a problem with my project.
i use the midio128 and when shorting the pins directly on the board (with a small piece of wireup)i get good results.
problem is my  actual wires running to the on/off buttons are very long. some are 4-7 m long.
when i push them, i get (on some) several on/off  messages. they are all traceable and reoccurring.
as i mentioned before. i use wireup cables, i need them because the buttons are very close to each other.
i had a problem managed.
these are not standard buttons but 2 pieces of aluminum with a piece of insulator between them. when applying pressure to the top foil i close the circuit.
trouble is there was a lot of on/off jitter. i fixed that by changing the debounce value in the  mk_midio128_syx.
maybe i can fix these problem using a similar method?
is there something i can change that will rise the tolerance of the buttons so they want be effected by false positives?
please don’t tell me to rewire  :stuck_out_tongue:
similar problems?
http://69.56.171.55/~midibox/forum/index.php?topic=2893.0
there’s also the thread about the added capacitors. will it help stable my inputs?
An impressing pictures! :slight_smile:
Not sure if caps will really help, maybe it’s better to reduce the value of the pull-up resistors on the DIN module.
You don’t need to replace them, just solder the resistors in parallel.
E.g., with a second 10k in parallel, you will get a 5k resistance
You could try this for 1..8 inputs first in order to check if this really helps
thanks TK
is this what you mean?
No, this is a serial connection which increases the resistance.
Parallel means: just connect them together
sorry.
like this one for each ressitor?
Yupp :wink:
M
