Hi
can i use this with normal MIDI-cable or only with the screw-able connector for this Port???
best regards
Zossen
Hi
best regards
Zossen
There is no special plug for this, it’s meant to be used with DIN plugs.
So, yes, normal MIDI cable will work.
THX so i can use all standart cable and not only this
part
so its a good alternative
It does work with regular DIN connectors.
No. There is a special plug for this. It has a little ring on it that lets you screw it to the socket tightly. Absolutely awesome for stuff that stays plugged in for a while. :hyper:
http://www.reichelt.de/?ARTICLE=46262 (as seen above)
Hi
best regards
Zossen
I bought one of these from DigiKey and they work great.
