Hi Everyone,
Been busily completing my MB6582 build. Base board went together without issue with everything (all 8 sids), working correctly on first power up (awesome machine!).
I finally got all the remaining parts for my control surface last week and have put it all together. All was going well there too until Sunday afternoon when the Mrs was hounding me to do other more important things (like grocery shopping)! Arrrrgggh.
In my haste I put the panel on my CS, compete with flat LED’s etc, everything in place, LCD mounted and Waldorf knobs installed, all ready to go. Obviously NOT following Hawkeye’s instructions at this point due to the implied rush and having read them a few times.
What I’ve stupidly done is assembled everything before putting it in the pactec case. Assuming the CS board and panel would slide into the pactec from the top, then be screwed down onto the 4 corner tabs. Dunno why I was thinking this.
Of course this can’t be done as the panel needs to be mounted to the top of the case first with the CS board then being put onto the panel 1 final time, lining up the leds and buttons etc.
I figure DOH, ok, not so bad. I’ll just pull everything apart and do it the way it’s meant to be done. But herein lies the problem. I can’t get the knobs off without causing damage.
I’ve got a chip puller that I put either side of a knob, gives quite a firm grip on them, but I can’t budge the damn things. I pulled one so hard it actually ripped the encoder clean out of it’s metal mount (the ones used to disassemble the encoder to remove the detents). So I can’t put enough pressure on the encoders to get the knobs off.
This leaves me stuck. I have one possible option that is a little drastic and depends on the structure of the board but, theoretically, it should be possible to remove a square of the CS circuit board at each corner (Where the mount holes are), which should then let me slide the entire panel into the case with the CS panel sitting on the 4 corner tabs as it should (I have corner screw holes in the panel). I could then screw it into place and all would be well (sortof).
Short of that I’m not really sure what to do. I can really have at it essentially stuffing all my knobs and encoders until I can get the panel off. But I’ll then have to fix all the encoders (or de/resolder new ones), plus get 15 new knobs and there’s potential there to damage a perfectly well assembled control surface board and panel as well.
I can’t tell you how pissed I am with my self wife, for this terrible mistake right at the last step. I was literally finished had I mounted it on the case first.
Now I’m stuck.
If anyone has any secret method for removing encoder knobs I’m all ears. Would freezing them or heating them help?
I would like to get it apart anyway as I realised I also haven’t put a window above the LCD (not that it really needs it, but it would be nice), and I would like to JB Weld the encoders so those pins holding them together can’t move or get loose, but I can’t disassemble it at the moment.
I’ve seen posts where people removed the corner tabs from the pactec entirely (for those with screwless panels), but I’m not sure how the control surface can be mounted in that case?
Any and all help much appreciated.
Cheers,
Arkay.
