DeSoldering Tip
If you have no desoldering equipment, a quick method is to strip 1 cm of insulation from a piece of multi-stranded wire, loosely twist it and dip the wire into some flux. Heat up the required joint with the iron, and apply the wire. Most of the solder will be pulled up into your wire by capilliary action.
Nice tip,thanks
Cheers
Paul
I will try this next time :slight_smile:
Thanks for sharing !
Cheers
orange
