defect mixer usable?
I can buy from someone a defect (blown up with 400V and beer) mixer for a very soft price. I want to know or you can use the poti’s and faders or are they damaged?
sorry for my bad english
well,.. you can quite sure re-use the case.
And depending on where the beer was poured over, the pots and faders *should* still work if there didn’t went any beer directly into the fader-slots.
..usually some salty french fries or a couple of fried eggs should help the mixer with the hang over…
seriously you need to check pots and faders for “ohmage” 10K is what you need, linear; usually you don t get those in audio mixers anyway.. as said before, a nice case is always a good find and the transformer could be reused
if you post some pictures …
Simone
I haven’t a image but it’s a behringer pro mixer djx700 and it looks from the outside as normal (no damage at the outside)
I can buy
… BUY???  :o
I think you shouldn’t pay for a defect Behringer Mixer! They’re are almost for free when buy them new.
Greets, Roger
i’m talking about € 5 and for me it’s for the parts al the knops you can’t get for €5 and when the poti’s are also working and goot it’s a cheap option to get parts
Ill buy it for 6.- €  ;D  ;D
€ 6.12, going Once, going Twice…
…Sold! for 6€12 to asafnetzer!
bad luck socrates  ;D
You *should* be able to reuse the EQ-pots as they are usually linear. You won’t be able to use tha faders. they’re definitively logarithmic
(as cimo said)
