default.ngc
Hi all
Yesterday, after two years designing and “playing” with hardware for midibox NG, I just finally compil my first app… the default midibox_ng_v1
A new world is opened to me and I hope I can “custom” the ng for my fader system, maybe a dedicated app !
Today I try things like reducing SRIO scan and AOUT number, as deactivated unused hw in my design like encoder OSC etc…
Now I have a question regarding the default.ngc file generated by the app when not present at the SDcard, where can I modify this to have my dedicated .ngc automaticaly generated ?
Best
Zam
I don’t know if you still need help on this and if it even helps what I’ve found. In app.c of the NG you will find
 // create the default files if they don't exist on SD Card MBNG\_FILE\_CreateDefaultFiles(); }
So at least it seems that you can disable the creation of the default file… I haven’t tested it yet…
And to load your dedicated ngc.-file you can use an NGR-script and the “load” command.
Should look something like this:
if ^section == 0 load xxx endif
Hello Fantom
Tks for your reply.
I think I’m aware about what you find at source code IIRC.
The point at the time I look at this is to understand where the default files generated get his definitions,
to generate a default file with my specification.
It’s not an major topic now for me, but still interested to understand the (soft) mechanic :slight_smile:
Best
Zam
