Hi all,
I was wondering if there was a reason to set the left-right oscillators with a different wave type (left is Pulse, right is Sawtooth) in the default bassline patch.
I discovered this thing when I checked my gear after expansion (now it has 2 stereo 8580’s and one mono 6581) and noticed that in the default bassline patch the left channel’s VU meter in my mixer was clearly higher than the right one.
I started checking thoroughly all the audio wires and SID modules with no results. It was when I connected an oscilloscope to both outputs when I noticed the (quite obvious) difference in the wave shape.
I can confirm this in the source code (sid_preset_bassline.inc, ca. line 45):
;; Voice #1
;; Flgs Wave AD SR PW_L PW_H Acc Delay Trns Fine PRng Port. ArpM A.S/D A.G/R Res2
db 0x01, 0x04, 0x00, 0xc0, 0x00, 0x09, 0x10, 0x00, 0x28, 0x80, 0x02, 0x28, 0x00, 0x1f, 0x05, 0x00
;; Voice #2
db 0x01, 0x02, 0x00, 0xc0, 0x00, 0x09, 0x10, 0x00, 0x28, 0x80, 0x02, 0x28, 0x00, 0x1f, 0x05, 0x00
^^^^ HERE IT IS
Bug or feature? ![]()
Many thanks,
RAZ
