Hey guys, I need some advice today.
I got myself an old (very old, 1983, same age as me!) C64 a while back to steal it’s SID, but I decided to use it with the Prophet64 cart instead. However, having had it running today now I’ve been home to get my datasette etc, It appears there’s a few things wrong with it, (ie, datasette won’t work with it, some RAM is not recognised).
So, I did get it to play the loading screen on my rick dangerous cart (best game EVER) with the accompanying tune so I could compare it to my newer 1990 8580 C64. As it turns out, the bass is much fatter and more grimy on the old 6581. It’s probably more distorted, but it just sounds more exciting. THis put me in a bit of a quandry since I can’t use this unit with the Prophet64 cart.
I’d originally planned to make a 6581+8580 dual MBSid, but then changed to a dual 8580. My reasoning is that with two 8580’s I can get 6-note polyphony. Other than that, I don’t think the 2x8580 has any advantage. (If Slorrin’s reading this, i’ll still get both 8580’s either way, one can go in my SID2SID/prophet64 unit.)
Can anyone help me out with some ideas and samples as to which direction I should go? Maybe I should build a 2x8580 AND a 6581, but I suspect that’s overkill?!
Oh, I should mention i’m a big fan of old monosynths like the SH09, SH-101 etc, does that have any bearing on my choice of SID??
