Decent 19 Case
Does anybody have a recommendation on a reasonable price/quality rack case in europe?
I bought some at www.pollin.de they are horrible. I think they are the same ones that banzai sells. They look the same as this DSC09758.JPG that Rosch posted. All crooked and you have to bolt all the panels together.
I have one of these: http://www.modu.it/slimlineeng.html and it seems pretty well built.
Oh yeah, good one. I forgot about that site.
P.S. the title should say: Decent 19inch case :wink:
Yep, the pollin ones are… not so great :whistle:
I usually use the Adam Hall 19" cases (available @ thomann.de for instance). Musikding.de has the same ones (it just doesn’t say Adam Hall on the box) a bit cheaper in 1U and 2U.
I need 2 1U 28cm deep 19" cases as well. I like the cases from modushop, even if they are €50 without internal mounting plate (= additional €10). @Shuriken; if you are still in need of cases maybe we can combine shipping? I don’t live very far from you :poke:
Alternative are the cases from Musikding; they should be back in stock any day now (says the sales rep).
I buy this brand since I am in electronics ( as it is Italian brand I found it at the corner shop when internet was only a dream )
it is well build and not very expensive and my 9090 is in one of these :smile:
Regards
Antix
Regards
Antix
Yeah, NorthernLightX and myself bought a couple of cases there. They are very good quality items. Only downside i can think of is the standard backpanel with the AC connector hole already cut out. Which is ofcourse great, if you are going to build something with AC PSU. However with any usb powered device, you need to replace the panel.
it would be so cool if they had a 3U case. they look very good.
AFAIK they do, they have 1, 2 3 and 4 U models (maybe not 3 and 4U in slimline but in other models).
They have a 3U Slimline: http://www.modushop.biz/ecommerce/cat204_l2.php?n=1. A 4U is also available. It is just not on their product page.
I know but not all the models have the IEC socket hole.
Anyway you can close it with a little metal frame.
Cheers
Antix
