hehehe - you’re not gonna trap me that way mate, I got enough email in my inbox as it is
still a long way to go before anything like that could even be thought about.
Once I get the 1st manufactured PCB run back (did the prototypes by hand), tested, tweaked etc, software finished and debugged, then MAYBE we might possibly think about perhaps doing a group buy
What goes in the triangle shaped holes? Did you find some triangle shaped LEDs?
Thanks Wilba!
Yes, I have triangle LEDs going into those holes.
I originally wanted a “halo ring” sort of thing, but after lots of experimentation, attempts at sourcing (read begging, extortion and death threats to get hold of) and breaking the Xzone-3d in Fabric while working out “how do they do that?” - I decided to go for the triangle LEDs. I really glad I did now, I’m well happy with the old skool/mil spec feel they give!
I need to say 1mm lasercut steel isn`t so heavy you might think, especially if you take into account strength it got with just 1mm thickness or even less. It is also way much cheaper than aluminum and can be painted using normal car paints. So, my advise for you that have some laser service at hand… try steal, and you want be disappointed.
I didn’t really think about going for 1mm S-Steel, it’s a good point you make about the strength vs thickness.
Exactly. 1mm is enough for biggest panels you want to make, and for smaller ones it is super strong. One times I couldnt afford to have another 3mm top panel as I already had 3mm acrylic subpanel so my fader shafts didnt stick out enough. Lasercut steal would be perfect but I didn`t know about the service in that time. I had so much trouble doing it right.
Do they have the same issues with laser flashbacks with S-Steel as they do with Aluminium?
Im no sure what you mean when say flashbacks. I actually never seen laser machine for metal in work as service is not in my home town, but according to material they sent me I see no problems. Line isnt completely smooth as CNC milled but it is still very good. I bet it could be much smoother if they adjust the speed and power better. I love lasers… made my life much easier and keep my hands in good condition!
Laser flashback occurs when you’re lasercutting a reflective material (like aluminium) - some of the beam reflects back from the cutting service and burns the laser optics.
