DAW integration of LED rings
Is there any way to integrate the 8xLED ring+Encoder card to some DAW (In my case Gig Performer)? I want to connect the Midibox NG to the computer by USB and I need a complete interation in DAW, it means If I change the values in the computer, the Midibox NG will receive the values, and the LED rings will show the actual value in DAW. Also I want to make some buttons with the same functionality.
Any idea!
Frank
Hello
Assuming you set your led type and value according to MCU chart (CC for Vpot/encoder IIRC) it should work…
side note: MCU Vpot have flip function, you’ll have feedback according to selected layer (pan, aux etc…)
Best
Zam
Any idea!
Frank
Totally possible. I do the same with Cantabile.
