T.K
21
I guess that you mean, that this only happens when the “Play” button is toggled in the Ctrlr editor or on the CS.
But that the envelope works correctly when MIDI notes are played, right?
Here is a new version which should fix the problem with the “Play” button: http://www.ucapps.de/mios/midibox_sid_v2_044_pre1.zip
Yes! Just fugured it out. Toggling “Play” don’t send note off.
But there’s still some volume offset.
With MP depth set to 32 I can get 0V Volume voltage. But it rises only to 2.5V with envelope triggered. And 1.86-4.37V range with MP depth 127.
1.Yes. 2.Yes
I got 0-4.97V voltage swing with all as you described, but MP depth set to 1 instead of 127. :wacko:
T.K
25
I just doublechecked your snapshot.
Of course: you’ve assigned the MP output to the volume target twice.
One time as generic Target1 and Target2 (which is normally not required), and then again with the “hardwired” targets Vol1 and Vol2
Just remove the Volume destination from Target1 and Target2
Yep. I found that this doubles output CV.
Here’s some settings/voltage readings.
igi
27
WOA!!!
That’s great news!
Now I have to take my Dark matter from dust
Best regards, IGI
Grate news indeed! Have to take my box from the dust too… And build a studio…
