In normal use the envelope is generated when the module receives a gate pulse or is triggered by a specific input.
_ Ok I think its like that: _
If on the Gain of the VCA is no Voltage, the VCA outputs no sound.
The Gain of the VCA, is controlled via the Envelope
The Envelope:
You press a key, and the keyboard send a “Gate on” Signal.
With this Signal the envelope starts (triggers):
Attack comes and the Voltage get higher, until Decay is reached.
Decay hold this Voltage as long a new Gate Signal comes.
If this is a “Gate off Signal”:
The Suistain comes, it gives a static signal, until Release comes (and acts like the decay)
Then the Release comes, and the Voltage goes down. (Release acts like Attack only invertet)
If this is a “Gate on Signal”:
I am not sure.
But if this so works, I think midibox SID can handle this. The ENV output on the CV board, have already integratet this. (correct me if I am wrong please)
Because the Midibox ENV is software based (?) and it already triggers the envelope with the gates? So I dont need any Gate signal on my layout because I use the digital ENV for my TB303.
2nd need is the Resonance Pot, I want it to CV. Since it is Stereo Pot. And feedbacks Signals, I need a simply dual VCA, or a simply VCR (voltage controlled resistor) which can handle this.
The one part of the Stereo part, mixes extra Accent to the VCF. The Other part of the Stereo Pot Feedbacks the Filteroutput to the Filter input or whereever :-).
So maybe the Resonance Pot-problem, can make with a single VCA, which only feedbacks the signal, the extra accent can be emulatet, since the Single VCA is driven via CV over the Midibox, it must be possible to add, by turning the RES-Encoder on the SID - to add a bit Accent to the Velocity CV-Out…but Since I am a analoge human I dont know if this possible, and if it is possible I dont can programm that :-.… So This must be a Dual VCA (op amp or what ever…)
Cool Idea is the
MB-sidechain
You take the basedrum amplify it, connect it with a yellow LED, and put on the LED a LDR, the output of the LDR must be amplifyed too, ant then you go in a MB-AIN.
Here you can duck the MB-SID-Volume-Envelope, and you have a sidechain VCA, between: good sidechaincompressors outthere working with VCAs!
The point where the Sidechain in the SID-application must be, is, always on last position!,
Meens:
If you route a LFO a Envelope and the Sidechain to the Cutoff of the SID.
the Sidechain, can reduce the Controll-voltage, to the minimum, elswere, the LFO would amplify it agin 8)
But this of course is in first thing a programming thing
, the analog circuit, would be so easy.
And If you want the sidehain to be mor linear:
You must take instead of LED and LDR, Transistors!
Amplyfiy it Rectify it,- put it in the AIN (but more of this later)
The Other Idea, would be take, the sidchainsignal, and trigger the envelope with it, but the upper idea is much smoother
anybody can explain what a audio buffer is? is this done with simply building a OPamp - amp??? ???
