I’d still love to see some kind of CV-Input quantizer feature!
I remember TK mentioned that he was experimenting with some code a while back in the MIDIbox CV discussion thread. And we now have all those great scales developed for the MBSeq *hint-hint*
Too bad MIDIbox CV isn’t in C, otherwise I’d take a crack at it myself.
So far I remember, AC has developed a C based version to his Speakjet project. If the function is generic enough, it could also be built into the “analog toolbox” (which is written in C as well! :))
re. analog toolbox - hmmmm… but then i’d have to recreate all of my favourite MIDIbox CV features. hehe.
i looked at AC’s speakjet code and the most interesting part was the harmonizer.
stryd_one - if you’re willing to help, maybe we can steal the force-to-scale ASM code from the MBSeq
then the only thing we would need to do is read 0-10V from an analog input and convert it to the nearest midi note. the 1V/Oct standard is quite simple: 1/12 V per semitone or 1/1200 V per cent.
Question
Can the analog in accept 10V or do i need to scale it down? In any case, I imagine that it would be wise to implement some kind of opamp buffer.
I’ll leave the analog bits to you and then help nick the scale engine
Those two resistors can be any value (not too low I guess, or it’s a short) as long as they are -exactly- (measured, not from the spec) the same to within the error margin of the ADC. Otherwise you might not get exactly 1/2V/Oct
The divider takes care of the voltage levels, as explained above, but there’s more to think about.
You should also consider the output impedance. According to the Electronotes standard, the output Z of most synth circuits should be 1K. This is easy to arrange here. Besides computing the divider voltages mentioned above, arrange for the parallel resistance of the two resistors to be equal to the desired Z.
For this case, we want 0 to +10V to go to 0 to +5V, with a output Z of 1K (common for Electronotes circuits). Choosing both resistors to be 2K gives the required voltage reduction (10V max to 5V max), and in parallel they are 1K, a good impedance to drive other modules without worrying about shorted outputs.
My rule of thumb has always been: design a circuit to (a) be elegant, and (b) not burn up or cause other modules to burn up, no matter how stupid the operator may be.
Modify the Analog Toolbox by adding the scale quantizer code from the AC Sensorizer project.
Any thoughts on this? As I mentioned in the other thread, there’s an increasing demand for CV quantizers what with the resurgence of modular synth manufacturers!
Maybe I could do something about quantisation of incoming events (the harmonizer works too for incoming notes which get forwarded harmonized); there may be some remaining free bytes to squeeze that in…
I am not using any buffers, the approach is quite simple
(which does not mean I discovered this possibility quickly ::))
I disabled the AIN-Notification and assigned a countdown-number to each pin, for example 95 ticks for a full note for pin 1. The counters are decremented each clock cycle. When the countdown reaches zero, the AIN-pin is read (and the processing occurs).
Heheh I see you are counting from 0 when typing english and not code. This is how you know you are spending a lot of time coding
You are thinking about quantising the timing of the values, but sneak is talking about quantising values to a certain range (IE, note-to-scale)
is this a common expression when it comes to harmonizing (adapting notes to a musical scale)? Whenever I read the term quantizing in menues of music programs, it always meant shifting the notes to the right place in time… :-[
AC - if you look at the pictures of the modules that I posted in your AC Sensorizer thread, you’ll see that they’re all called “Quantizers”, which means they take incoming voltages and force them to a note scale using the 1V/Oct standard
Is that still too hard to adapt to the AC Sensorizer, or should I continue with ripping the juicy bits from the AC Sensorizer and insert them into the Analog Toolbox?
Well, the main issues (me having no AOUT hardware) still remain; so unless you don’t release a stand-alone harmonizer, I don’t have no problems with some decent code-ripping (I love being credited, arrrr ;D)
I think it would make more sense to integrate the harmonizer to the Analog Toolbox: the sensorizer software is tied to the AIN-sensors, beginning with the bankstick patches and ending with the menu-control based on selected AIN-pin-numbers… it would require some efford to strip the unnecessary things and only god knows if it would still work afterwards… it’s surely easier to add the two ACHarmonizer sourcefiles to a new or an existing project (maybe you also need the ACToolbox and ACMidiDefines, but that should be all). The files are well prepared with accessors to be used without having to change a lot
Moreover, I was not very pleased with the situation of the SpeakJet project, which was branched very shortly after I released the first beta sources - anyway, I understand the reasons and the momentary solution is one I can live with. But if I’m honest, I am not keen on repeating this with the ACSensorizer.
Well quantising just means that you are making a value fit within a predefined set of values …so the way you and I and most people think of quantising is on the time scale, rather than quantising on the pitch scale.
Only people who work with CV really say ‘quantising’ to mean ‘harmonising’. It is technically correct, but I think that because traditional sequencers only quantise on a time scale (not pitch) then we don’t think of it that way.
