CV-out plus envelope??
I’m wondering, is it possible to construct a CV interface to control an external filter, that incorporates an envelope triggered via MIDI?? Possibly also with an LFO??
I’m assuming since MBSID incorporates software envelopes, they could be re-used for this purpose??
MBCV/Analog Toobox?
MBCV doesn’t support software envelopes/LFO (too much programming effort…), but yes - a lot of possibilities are already given by analog_toolbox, MIDIbox FM, MIDIbox SID V1 and especially MIDIbox SID V2
The easiest way is probably the usage of the MIDIbox FM firmware, as it’s more flexible than MIDIbox SID V1, and provides a SysEx editor (so that you don’t need to build a Control Surface)
The best solution is the usage of MIDIbox SID V2 (but there is no SysEx editor yet…)
The most flexible solution is analog toolbox, but it requires programming experiences for extensions.
Right, think i’d better go take a look at this analogue toolbox thingy then! It was just an idea I had on my way to work and I got a bit excited by the idea. Basically, i’ll be getting a CZ101 at some point, and I want to use that for mono lead and basslines. With the addition of an analogue filter, I think it’ll be killer!
EDIT: That’s 4000 posts Stryd, nice work!!
