I have a wall adapter lying around that delivers 700mA, will i be able to use this? or do i need changes in the design, or maybe even a new adapter?
thanks,
Joey.
thanks,
Joey.
For what?
Mostly it is stated in the schematics, how much current you will need.
A MB64 e.g. requires about 300-500mA and a LC (with motorfaders) more than 1A.
I’m building a mios based box, with 24 pots, 60 buttons and 2 encoders. I will not use a LCD.
The scematics say i need 500mA
Without the LCD (it drains the most current - with the backlight on about 200-300 mA) you will need nearly nothing. I assume you will have some LEDs?
However, the current will definitely be under 300 mA without a LCD! So have fun with that adapter! ![]()
yeah, I’ll be using ~18 LEDs.
thanx
