Hi, I have a Crystalfontz LCD (CFAH2004A-YMC-JP) with backlight, only the backlight does not go on.
I’ve got a PIC with only the bootstraploader on it. Today my neighbor and I checked all the wiring, and all boards connected at the moment, for shorts and other problems and found none.
What I do see when the power is plugged in is blocks on row 1 and 3 (it’s a 20x4 LCD). I can play with the brightness of the blocks by tweaking the pot, but the other pot does absolutley nothing for the backlight. We also measured the response from both pots, and they’re both working.
In the techsheet for the LCD it says that the max voltage for the backlight is 4,8, and the typical voltage for the BL is 4,5. I measure 5,12 - what can I do to get this within specs, or is it more probable that the BL is dead already?
I sort of knew that the logic was still ok, cause the lines showed up (already read that on the Crystalfontz forum). Am reading all posts over there now to see if similar problems are described.
I am using a Core_V2 board, with 10k pot and all other components that are in the design.
I will make an extra check on the - and + of the backlight, but am 99% sure that i did it correctly… Will post followup this afternoon.
you could try another voltage regulator, as the voltage tends to vary between different specimens. Or you could put a series resistor in the path to the +5v supply pin on the Backlight. I think I used about 200ohms on my old midibox 64. (not in the mood for pulling apart right now!)
Arrgh! it is just next to me so I pulled it apart anyway! I actually had a 10k pot in series with the LED backlight… (not a suitable value, or current rating actually! Better to use a 1kohm, set to a setting that gives good brightness, take it out, measure the resistance, and then substitute a fixed value 1/2 watt resistor in its place depending on what the current rating of your backlight is. (power = volts x current)
that is upposed to be happening, it’s the LCD’s way of telling “hello, i’m alive, please send me some info to display…”.
You should also chek my topic in Testing/Troubleshooting, as you’re probably facing the same prolem flashingyour PIC’s, Thorsten’s idea is that I’ve used an older version of the bootstraploader, namely 1.1 instead of 1.1 b. Since you burned those for me I assume you’re using th same version. Could you confirm that?
