I have access to a lot of copper coated pcb material and thought that I would give the press-n-peel method a try. Is there artwork on the site I can use for this purpose? Is it the .brd files that is opened with the Eagle software?
I already sent the converted .brd files to Poeleq (if I remember right). They’re graphical files (.tif I think) and can be directly printed. As soon as they’re up in the portal, you can download them there.
Or you can make it on your own (a little tricky at the beginning): Open the .brd file with Eagle, export it as an image (hiding all not copper layers!!) and make it black/white (and deleting here and there). Not to hard, but quite some time.
if someone could either post the pdf or image files up it’d be good for others reading the thread. If noone’s got any webspace mail them to me [tub at tubs dot org dot uk] and i’ll chuck them up somewhere.
well, i don’t think you would recieve them at yahoo. they have attachment maximum size i think, so I sent them to poeloq for the portal. (they’re 3,5MB).
Why aren’t those .pdf/tiffs on midibox.org? Everything… anything? No updates, for a while, whatsoever..
Sorry, no dis -  but midibox.org could be a  download site for .mid files (as I got, for search results for “midibox”, while a go), maybe some day it will, as nobody seems to care about it
OK, Poeloq might need so help, but I don’t: linking something, from somewhere:
