create random values on PIC?
Hi all,
I need to create random values in the range 1-10 or so in my application. Is there an easy way to achieve this within the PIC?
Thanks, ilmenator
Well..
Many people have found this secret “hidden” function, by using compiled Midibox64 application and failing to reading the documentation :smiley:
I don’t know the software solution (see the examples), but if you leave analog input pin floating and read the value and scale it down to 1-10, would that be random enough?  ;D
Moebius
There’s already a RNG in MBSEQ :slight_smile:
;;  This function generates a new random number
;;  OUT: new random number in SEQ_RANDOM_SEED_[LH]
SEQ_CORE_GenRandomNumber
SET_BSR SEQ_BASE
movf SEQ_RANDOM_SEED_L, W, BANKED
mulwf SEQ_RANDOM_SEED_H, BANKED
movf TMR0L, W
addwf PRODL, W
movwf SEQ_RANDOM_SEED_L, BANKED
movlw 0x69
addwfc PRODH, W
movwf SEQ_RANDOM_SEED_H, BANKED
return
Scope the Humanizer functions out for a scaling example:
;;  this function applies a random value to a byte
;;  IN: pointer to byte in FSR1
;;      intensity in TMP1
;;  OUT: modified byte
SEQ_HUMANIZE_Modify
call SEQ_CORE_GenRandomNumber ; generate new random number
;; scale depending on intensity
rlf TMP2, W
rlf WREG, W
rlf WREG, W
andlw 0x78
mulwf SEQ_RANDOM_SEED_L, BANKED ; scaled result in PRODH
;; add/subtract depending on SEQ_RANDOM_SEED_H[0]
BIFCLR SEQ_RANDOM_SEED_H, 0, BANKED, rgoto SEQ_HUMANIZE_Modify_Add
SEQ_HUMANIZE_Modify_Sub
movf PRODH, W
subwf INDF1, W
;; saturate on overflow
IFSET WREG, 7, movlw 0x00
movwf INDF1
;; value should never be 0x00
movf INDF1, W
skpnz
incf INDF1, F
return
movf PRODH, W
addwf INDF1, W
IFSET WREG, 7, movlw 0x7f
movwf INDF1
return
:slight_smile: TK beat us to it again!
Okay,
thanks for that piece of code - I wouldn’t have found it, as I have no MBSEQ  :stuck_out_tongue:
Now, I don’t know much about Assembler, what does the code do? What is the range of the values that are created? How can I use it in my C code?
In my app generating the random values is not a real-time issue, so is there any other piece of [tt]C[/tt] code that might be easier to understand for me and which does the same?
Sorry for my ignorance, I’m still learning…  ::slight_smile:
Thanks a lot, ilmenator
The "sid_random" application gets use of an external "real random" generator
In C, the "software random generator" in SEQ_CORE_GenRandomNumber function would look similar to this:
[code]
unsigned char random_seed_l;
unsigned char random_seed_h;
void gen_random_number(void)
  unsigned int tmp = random_seed_l * random_seed_h;
  random_seed_l = TMR0L + (unsigned char)(tmp & 0xff);
  random_seed_h = 0x69 + (unsigned char)(tmp >> 8);
[/code]
Maybe with some additional XOR operations the random value distribution could be improved, but I'm not an expert on this topic...
[/code]
