I’m trying to build a MidiboxSid controller in my Clavia G2 - so far so good. But I’m having problems understanding the following from the CC-implementation:
LFO1 Mode                Â
Bit 0: Enable LFOÂ Â Â Â Â Â Â Â Â Â Â Â Â
Bit 1: Sync with assigned note events  Â
Bit 2: Sync with all note events     Â
Bit 6-4: Waveform            Â
      0: Sine             Â
      1: Triangle           Â
      2: Saw             Â
      3: Pulse            Â
      4: Random            Â
      5: reserved           Â
      6: reserved           Â
      7: reserved          Â
Example: 11h = 17 = Enable & Triangle Wave Â
         15h = 21 = Enable & Triangle & Sync
I don’t understand the “bit 6-4” concept, and I can’t seem to figure it out backwards since only Tri waves are mentioned in the example.
It should be stated that I really haven’t done much Hex/Bin calculations… ever! :-\
Any help would be appreciated!
Cheers,
Mikael
