Corrupt application on PIC
Hi guys,
Last night, I tried uploading programs one right after another on my core, just experimenting ;D  After successfully loading 4 application, the one that corrupt my PIC is when I load the LCD benchmark app on top of the router app  :-[
Now the core only displays the MIOS version (with TK’s trademark) upon boot up. Can I still replace the corrupt application? It seems to me that the bootstrap and MIOS is still working, or am I wrong on that assumption?
Questions:
  1. Should I reload the bootstrap?
  2. Should I reload MIOS?
  3. How do you erase the PIC completely back to factory specs?
Just FYI: I own a PIC burner (parallel version)
Please advice..thanks
Hello, why do you think your pic is corrupted ? (i think it’s not, as long as you can see the MIOS version etc :wink: )
Did you try uploading another app ?
If you cant, in any case you should not need to reprogram the pic with the burner.
Do your pic send an upload request at startup ?
Dont hesitate to reupload mios, or apps, even experimental ones, i doubt it’s possible to ‘fry’ the pic, even with very bad code :wink:
Did u try to upload another App? Or does it freeze or something?
We can’t say much if you didn’t try right :wink:
Yes, I tried uploading another app and even the MIOS and its not taking it. I don’t remember the actual error, coz I’m at work right now.
I will try to upload again tonight and I will post the results.
thanks..
There is the 1st level bootloader that is burnt onto the pic.
Then there is another 2nd level bootloader coming with MIOS; this one is active for about 2 seconds after rebooting. If you have a corrupt application that is blocking the incoming SysEx events, try sending your application immediatly after rebooting (in that 2 second range of the 2nd level bootloader).
Let us know if this helps.
Cheers,
Michael
Actually, I know that a bad code can not fry a PIC. What I meant is a corrupted code “inside the PIC”.. Sorry for not being detailed about my question.
Cheers,
Michael
Michael,
That’s it!! ;D it work. ;D You’re absolutely right… I just need to time the upload request. I reloaded MIOS again.
That’s only partially true. The PIC can always be re-burned if you put bad code on it - unless of course, that bad code causes the PIC to behave in a manner which could cause it to sustain damage from other sources… Thankfully, that’s pretty uncommon :slight_smile:
You know… sometimes I got the feeling my application code has the power to desolder a cable when I don’t look and connect it to some totally strange other position where it makes me a lot of headaches until I notice it  :stuck_out_tongue: ;D ;D
great to hear it worked for you docbrown,
keep it up!
Michael
