Core32 resistor networks
I just realised I soldered the resistor networks R30-33 direct to the board, instead of using the little sockets.
Do they need to be removable?
Thanks :slight_smile:
It depends on what you want to do with the board. I soldered mine too. It is a sequencer and will probobly never change job. I dont’t think it is a big problem it you should change your mind anyway, just desolder them or cut them up and desolder them pin by pin and get new ones.
Thanks
