The Core of my SEQ v3 is working. But only after i’ve grounded pin 1 of the pic for a while. When I power up the Core, I get nothing on the LCD. But after doing the grounding trick it starts up. I was able to load MIOS and the SW.
But I can’t see me doing this each time I want to use the SEQ. Any suggestions?
my first statement to this issue won’t help you, but I must highlight this: thats a very interesting observation! I will add the reset trick to the troubleshooting guide as an important experiment to check, if the core module is booting thereafter.
But before, the reason for this failures has to be found out of course. It’s propably a power issue - maybe your PSU doesn’t deliver enough current during power-on, so that parts of the PIC is not properly reseted?
I guess your LCD has a backlight? Did you already try to boot the MIDIbox without the LCD backlight connection?
When powering the core modul with J1 you should have between 7 and 10V. 6V is a little bit to less. The voltage regulator on the core board needs the higher voltage for right working.
