Core V2 rebuild to Sid V2
Hi there!
Been away for long time now…
And I decide to rebuild my Sid v1.7303 to the new v2.
And keep my old core V2, just for now…
(I got the Pcb from Wilba but i haven´t got the time to rebuild my sid)
And I have some questions, (it´s like start all over again).
When I look at the new core V3 the PWM on J10 is connected to Pin #17 of PIC, do I need that?
And when I look att my other core V2 (slave) I didn´t connect SC on J4 to Pin #28, why???  :o
I think I left that for a reason…Hmmm
On the slave cores do i need the R12 1k on J4?
And another thing…on my master core i didn´t wire the J7:SO/PIC to the SID CLK pin.
The SID running on the 1 MHz oscillator instead..Can I keep it like that?
I just want do do this the easy way… :wink:
Haven´t got so much time with 2 small children…
Like I said, been away for a loooong time..
Thanks
Christoffer
Welcome back. I’m in a similar position- been away a long time. Now I’m working on one of Wilba’s MB-6582s, which is massively more ambitious than what I was working on before. And I seem doomed to make all the mistakes I made the first time, all over again (just trashed another LCD) :frowning:
I’m sure you’ll do better than me though :slight_smile:
a|x
Welcome back, Christoffer! :slight_smile:
Your questions are answered in detail here:
http://www.ucapps.de/midibox_sid_manual_up.html
and here:
http://www.ucapps.de/mbhp_sid_old.html
These are mainly quality improvements
It’s better to remove the oscillator, and to clock the SID module from the core. How you are doing this (via CORE:J10 or with a directly connected cable) doesn’t matter.
Without this modification, drum sounds could be triggered twice
no (only required if MBHP_IIC_MIDI or similar IIC devices which require clock stretching are connected)
Done!!
Works great! Thanks!
Next thing is to remake the matrix, the old one working bad..
The button i used for that is taken from and old code/cardreader lock…
Christoffer
