My problem is that I connected my midibox to my computer last night for the first time to test it and i was getting no signals.
So i tested the voltage on the PIC and the Opto-isolator and got just under 4volts on all of them. By the way i’m using a 9v 500mA power source.
I then went on to the MIDI interface Troubleshooting:
test prog1- i have no idea what this is saying and can’t find any reference to it anywhere.
test core1- the core came from smashcore so i assume it does.
test core2- the core is a core_R4D so i figure it’s revision 4.
test core3- the solder points are beautiful.
test core4- i get 4volts for everything besides pin 20 on the PIC, which i get 2volts at.
test core5- all test @ 4v
test core6- looks good.
test core7- looks good.
test core8- looks good.
test core9- as far as i can tell this looks good.
test core10- skipped this because i’m getting 0 signals
test core11- skipped this because i’m getting 0 signals
test out1- this is where i think it shows what’s wrong, when i wire up an led to the end of the midi cord the way the image at http://www.ucapps.de/howtodebug/mbhp_core_extract_out_led.gif shows it doesn’t light up.
so i checked it with the middle pin as the ground and that lights up with the positive coming from both m- or m+.
test out2- i haven’t tried this yet but am willing too.
i have my midi cords wired straight to the core since i forgot to buy midi connectors when i ordered my boards.
i can supply pictures if that would help.
-Ajax
