Help needed! Quick fix preferably ;).. probably faulty cause my pcb is a real mess.. not to mention my soldering. I could use some advice to pinpoint the problem. Anyway, here it goes:
measuring pin 1 to 12 (power, ground), where Im supposed to get 5V I get 0,5-0,3V, same for the whole board so there must be something wrong with the power supply to the board, early in the chain. Ive tried two different power adaptors - one 9V with 200mA and one 8V with <3A.
Measuring at J1 gives a proper result, and measuring with one pin of the multimeter at J1 and the other at various places throughout all modules (only where its supposed to though) gives a good reading of around 5V.
IC3 (7805) gets very hot really quick though, so I am suspecting a short somewhere, but I could use some help pinpointing the exact location. I cant find it anywhere. I am quite sure I have all the correct components with proper values and anything - the ceramic caps are suspicious though cause they dont look anything like those on the pictures on the net - can the problem have anything to do with these? I dont know much about electronics really, just following the plans and instructions so any help whatsoever is welcome ![]()
Btw. my core is built from the plans on www.ucapps.de.
peace out fellow DIY-ers!
