Hello,
first I’d like to thank everybody who helped to create and improve this beautiful project.
I had a lot of fun already, although I got stucked now:
I soldered the core module and tested voltages like shown in the manual.
Everything was fine so I plugged in my pic 18f4620 and started MIOS Studio.
The Midi in Monitor showed the periodical request messages, so I knew pic was alive
and midi out of the core was working
I tried to upload MIOS but had to read this message: “Error: Received unexpected Upload Request”
The Midi in monitor kept on displaying request messages instead of uploading confirmations.
I checked my midi cables / midi interface by looping the cables with a female adapter, was ok.
Then I took out the pic and bridged the rx and tx pin of the pic socket. that loop also worked fine.
then I did the led tests as described here : http://www.ucapps.de/howto_debug_midi.html
the results:
test in3
led flashes for a tiny moment when powering up but then stays off
when switching off the power, led lights up and fades out with a curve that rminds me at capacitors.
test in4
at vss-ic2 pin 6 its the same thing
at vss-ic2 pin 8 it lights up but doesn’t react on midi signal
test in5
led stays off
I checked voltages at pic an ic2 a million times, same thing with resistor values and
diode/midi connector direction (they should be ok anyway because of the succesfull loop test)
i checked soldering with magnifiying glasses and a multimeter but could not find any bug.
this seems paradox to me.
through I can make a midi loop at the pic socket, there must be a signal.
but the led shows no midi signal at no time and even behaves strange (test in 3).
after two day of thinking reading and overchecking I am running out of ideas now.
thanks in advance for any help…
Lötmann
