dondo
September 10, 2008, 2:55pm
1
I just built the core module.
I checked all the voltages I can.
I mounted the pic18f4685 (programmed with the bootstrap loader with picpgm) and the 6n138 in their sockets.
I have connected an LCD 16x2 to the core.
I can see the first row light and the second row dark.
If I check with the midi in monitor in mios studio i have no midi messages. (the problem is not my pc because i can read any other midi instrument.)
If I test the voltage of the tx pin of the pic I can read 3.66V if I reset the core module sometimes I get 4.98V. while my rx pin it’s always at 4.98V.
If i connect a led to my midi out it never turn on!
I have tried to follow the midi troubleshooting but without success
What’s wrong? ???
please help me!
DenDer
September 10, 2008, 3:33pm
2
Did you try another optocoupler? Most of the times its the opto.
dondo
September 10, 2008, 3:41pm
3
no. I haven’t another one I have to buy it.
Do you think I have cooked my optocoupler?
Is it so easy to burn?
nILS
September 10, 2008, 4:06pm
4
DenDer: You do realize the opto is hooked up to the MIDI In, right? So, your answer is, um, kinda pointless :
Dondo: Try running all the MIDI Troubleshooting tests as described on ucapps.de . Then post the results here
DenDer
September 10, 2008, 4:34pm
5
Damn…didn’t realize that stupid stupid :-X
@ Dondo, did you burn the pic yourself with the bootstraploader?
cimo
September 10, 2008, 4:39pm
6
dondo and dender … eheh :
dondo
September 10, 2008, 4:59pm
7
Yes! I burn it myself!
I burned it in gentoo linux system with the last wine because on xp I always have problems to use my programmer!
It worked i think! the verify was successful.
I did it with picpgm.
dondo
September 10, 2008, 9:07pm
8
This is my experience with the midi troubleshooting page
* TEST PROG1: my pic is burned sucessfully
* TEST CORE1: I have the A10.000 FD3u4 crystal on my board
* TEST CORE3: there aren’t missed junctions or bad solderings
* TEST CORE4: I have 4.98V in all the Vdds (except fot TX pin of the pic that oscillate from 3.66V to 4.98V)
* TEST CORE5: I have 4.98V in all the grounds
* TEST CORE6: The polarity of my MIDI plugs is OK
* TEST CORE7: The polarity of the protection diode D1 is correct
* TEST CORE8: My R8 and R7 are 220 Ohm 5% tollerance
* TEST CORE9: The midi out of my core is connected to the midi in of my Edirol UM-2 midi device
* TEST CORE10: I would like to have a lot of request messages connecting TX pin to RX pin, but I have nothing
* TEST CORE11: I would like to have at least wrong sysex messages, but I have nothing
* TEST OUT1: If I connect a LED to my MIDI Out port sometimes it turn on for 2 seconds (strange just sometimes)
* TEST OUT2: I have tried to disconnect the middle pin of J12 (ground line of MIDI Out port) but without results
What’s wrong guys? :-\
cimo
September 10, 2008, 9:16pm
9
What’s wrong guys? Undecided
does it really need explanation..
assuming is the mother of all evil
dondo
September 10, 2008, 9:25pm
10
I mean making this test ( http://www.ucapps.de/howtodebug/mbhp_core_extract_measuring_gnd.gif ) I got 4.98V in every ground point
cimo
September 10, 2008, 9:34pm
11
ok sorry, as i ve stated before assuming is evil..
..reading back you don t mention trying to upload MIOS or applications , what about that..
EDIT you may drop by the chat right now for faster troubleshooting
dondo
September 10, 2008, 10:08pm
12
Nothing can be uploaded into my core module…
there is no way…
I have tried with mios in 3 ways
waiting for an upload request (that never arrive)
smart mode without results
manual mode (with this one i get upload succeded but i don’t see changes neither to the display)
cimo
September 10, 2008, 11:07pm
13
hi
if no hardware problem can be found i suspect that the bsl hasn t been correctly burned.
i can t think of anything else
simone
>there is no way…
>1) waiting for an upload request (that never arrive)
>2) smart mode without results
>3) manual mode (with this one i get upload succeded but i don’t see changes neither to the display)
Manual mode will always succeed, because it’s not checking to see if it got there.
That means nothing is talking to the display.
You probably need to burn the bootloader into the PIC again. It does not appear to be running
Your power readings look good, I assume your 7805 is not burning hot. If your crystal is OK, then
you are down to a blank PIC or a bad PIC. PIC’s are usually pretty tough.
But I’m just guessing.
Good Luck,
LyleHaze
nILS
September 11, 2008, 9:10am
15
Don’t assume
Never rule out bad soldering/joints
Reburn the PIC (make sure to have your programmer read/compare it after burning)
Cimo: Awwww, she is soooo cute. When can I marry her?
nILS
September 11, 2008, 7:04pm
17
Deal. That means I’ll have to sell my mom, but hey. Although they actually offered 30 camels and 20 goats for her in Tunis. What will I do with all those goats…
dondo
September 11, 2008, 10:45pm
18
UPDATE: on another board I fixed a bad solder, and now the optocoupler test is OK. I was able to load MIOS (the upload request was being sent prior to loading it), but when I restarted the core nothing happened, and the display still shown the 2nd row dark.
what’s wrong now?
