Nobody ???
Clockbox ???
AFAIK midi clock is sending 96 pulses per beat.
stryd_one is right, I think clockbox shows bpm values.
OK, Ok sorry for the double post
sorry for the smiley (i never utilise it)
thank you for your answer
The problem with clockbox : it donesn’t receive midi clock just Send
Monitor is good but in assembler.
So i’m swimming a little
thanks
FAB
Yeh sorry about the wrong answer but to be honest I didn’t really think about it that much. The double post was a bit off.
So what’s wrong with MIDIMon?
I don’t want all the monitor application. I just want the code who convert received midi clock(0xF8) into BPM.
For include in application who i’m writing. After converting midi clock into bpm, i want to display the BPM on LCD screen.
excuse me for my english(cause i’m french).
Thanks a lot.
FAB
I actually enjoyed the smiley ???
;D
But you haven’t looked at the clockBox source in detail, haven’t you?
void MCLOCK_BPMSet(unsigned char bpm);
unsigned char MCLOCK_BPMGet(void);
unsigned int MCLOCK_GetTimerValue(unsigned char bpm);
It’s all there, the formula, the cycles, ASM-optimized divisions… you just need to crunch it down to your needs and implement a MIDI-Event notification that substitutes or calls void MCLOCK_Timer();
Michael
Ok, i try that
thanks
FAB
I don’t understand how too utilise this functions for receive midiclock and convert in into BPM. Can i have a short example.
thank you
FAB
Well, the code is commented very well and explains nearly everything. I understand it does not exactly what you want, but basically it’s all there, you just have to use the snippets that are relevant for your needs or implement clock_receive() handlers (which would be a good point to get help from us, because I see that is something more people might request).
If you don’t understand anything, this might be a bit too complex thing to start with, because divisions (esp. with high numbers) need mixed ASM code and I have to admit that there are some lines I don’t understand either, but to be honest: everyone has to fight with some lines of code. Don’t give up so fast!
All I can say is: the code is there, you just have to use it.
If you have specific questions and I know the answer, I might help, but I’m not going to do all the work for you (at least not now, maybe in a few months when my other projects are finished
Good Luck!
Michael
