bon bah ça n’en finit pas les versions d’ardour : )pour la dernière on a ca :
ugust 6th, 2004
0.9beta19 released
Although this is not the “feature-complete” beta19 I was hoping for, the set of changes are large enough to warrant a new beta number.
optimization flags patch from rob holland
drag-n-drop onto the editor track area where there is no track creates an appropriate track (or multiple, if appropriate)
URL-decode drag-n-dropped filenames
numlock can no longer mess up region dragging
if numlock generates whatever “Meta” is supposed to be then Ardour changes its notion of what Meta is.
if you see a warning about this in the terminal at startup, you should fix your keyboard map using xmodmap or equivalent
remove debugging output from process() tree
removed VST audiomaster callback debugging output
UI for VST plugins now offers presets
VST plugins now save and restore their state
“chunk”-using plugins are not yet supported
initial tempo and meter markers cannot be moved, even after editing
when cleaning up, prompt user about each unused playlist (options are delete, keep, cancel cleanup)
never decrease the number of panning buffers
Can’t create a new session on top of an old one anymore. It didn’t overwrite the old session, but you would get 2 master tracks and whatever was in the template, if any.
freezing tracks
implementation of freeze completely redone
unfreeze now works across invocations of ardour, so you can freeze, exit, restart and unfreeze.
freeze hides any insert editors, makes rec-enable and redirect display widgets insensitive and locks the new region.
freeze can be used over and over again
reworked relationship between bounce + freeze
removed “Loop Region”, renamed “Loop Selected Region” as “Loop Region” because of click-selects selection model
finally made solo button in mixer strip have the same font size as other buttons
removed edit history button and associated code from editor track
removed “automation style” buttons since they did nothing
more automation line + point patches from gerard
fix a couple of valgrind complaints
region trimming now obeys ignore-snap modifier
search unused playlists in Session::playlist_by_name()
added 2-phase unserialization mechanism (Session::StateReady signal)
empty playlists assigned to correct diskstream at startup
removed some debug printfs and some dead code
make Shift_R work like Shift_L
fix crashing bug with zero-length fade ins
internationalize all editor operation strings
transport control is insensitive when there is no session
fix problems with “region->fill track” where region is at or beyond current session end
new mixer strips use the current default width setting
always save to snapshot
snapshotting changes the current snapshot to whatever was saved
delete click_io object at session close, thus allowing new sessions to load correctly
fix problem with code ordering in normalize-region operation (undo after normalize-then-cut will now do the right thing)
force selection.clear() in file selection browsers when widget selections are cleared
committed patches so that ardour now compiles with gcc-3.4. There were several patches from multiple people. So please let Taybin know if he missed one.
patch from nick_m that fixes a problem with the editor-mixer button.
Maintenant, il n’y a vraiment plus qu’a attendre que la situation se débloque pour ce qui est des surfaces de controles… Faudrait peut-être aussi des meilleurs plugs LADSPA… enfin ça c’est qu’une histoire de goût
LEs vst sembel très bien marché maintenant. Ca me fait penser que je n’est toujours pas eu le temps de tester un auxsend d’ardour vers un effet “hardware” et retour dasn ardour. Histoire de voir si cette fameuse compensation “complète” de la latence s’appliquerai. bouhhhh le top, ressortez vos révebrs à plaques
