Control Surface proportions
I am printing the control surface picture to use that for the drilling marks, but because I don’t have any required applications, from that small image at ucapps… I would like to know what are the exact proportions to keep the front panel 1:1 with the holes of the circuit boards…
40 cm width seems to be pretty close.
Thanks,
Roope
if you mean the Schaeffer panel, use Front Panel Designer, and hit Ctrl+O which brings up the object properties window. then, click on each hole in turn and it will give you measurements from the bottom left corner of the panel.
Ok, thanks… I think I got it.
Tomorrow I will turn into mr. Driller…
R
