control of three or four axis
hello
    does anybody know if you can control three or four axis with a touch pad or joystick most are two axis x and y ive looked but havent found anything yet
but this doesnt mean it doesnt exist
  also does voti still do touch pads i couldnt see them on his web site
regards kris
http://www.voti.nl/shop/p/S-Touchpad.html
Greets, Roger
i am not sure but there is an alesis gear that will control 3 axis can t remember if it supports midi
simone
no it doesn t anyway here the link http://www.alesis.com/product.php?id=52
I’m not quite sure what you mean, kris.
3-axis require three dimensions :slight_smile:
Or it would mean you have an additional state for a 2D pad (something like a pressure pad below) to get 4 values. Maybe just a simple button would be okay, too. You know: without button -> CC#20/21, with button -> CC#22/23…
Or you just have to do some math to get the values you’d like to have. Eg you could split up the pad in a diagonal (not really, just mathmatically ;D ), that would mean you have two more axis and could extract four values, but then again for the price of non-simultaneousity.
You could take a look at my handTracker (in userprojects->speakJet thread), but it’ll take some weeks until I cleaned up my sources and you still would have overwork it a lot, 'cause even if it looks 3D, it’s still 2D :slight_smile:
Like cimo, I too thought about the airFX? Unfortunately it has no MIDI-connections.
Cheers,
Michael
thanks for the replies
  you get some joysticks that rotate as well as move in two axis ive  found the apem series 5000
  ive attatched the pdf but i dont think these are compatible with midi-box as these only have 5k pots attached
  i didnt get a price either
i could all ways use two  joysticks side by side to  control one thing but this would take both hands
  as to why  id want this video has a lot 3 axis parameters RGB etc so it would be handy
  trackballs could be an option as could virtual controls on touch screens
  the idea of the joystick with button is a good one as well
regards kris
[Apem 5000 Series.pdf](< base_url >/applications/core/interface/file/attachment.php?id=138)
[Apem 5000 Series.pdf](< base_url >/applications/core/interface/file/attachment.php?id=3279)
