Thanks, I’ve now connected them like above, but get no sound out of 6581. Testtone application doesn’t say anything, and interconnection test gives quite odd values, any ideas what might cause that? Here’s couple examples:
Yes, those are the measured voltages on the SID chip.
As it’s said in the main.asm file “By default all unselected pins are 0V, except for the CS# pin which is 5V”. On my circuit the CS# is too high, and all the pins are giving volts.
I have 12V for the 6581, like it’s instructed:
IC1:Vdd(28) and IC1:Vss(14) - it must be 12V for the 6581 SID
Please upload the interconnection test again and try it again. Perhaps diconnect the midi out cable from the core modul after uploading the application, so we can see that there´s no midi loop which controlls the application.
Haha, actually my Core module is not sending anything from midi (and that’s another problem solving episode), so loop is not possible. I’ve uploaded the applications without smart mode.
But I’ll try what you’ve suggested.
edit: Is it normal, that when you’re running interconnection test, and scroll up-down the modulation wheel in MIOS studio, the LCD on core gets nuts and gives only black bars on the upper row? I’m I having a crazy PIC or what.
