Connecting both a DIN and a DOUT
Hi.
How do you connect both a DOUT and a DIN to the same core using the SmashTV PCB’s, since J8 and J9 are on the same header. Can someone explain please!
Thanks,
Mick Berg.
hi,
you have to use two “single row” connectors, one for each module, Smash Tv sell such part :search for “5 pin Female Connector” on his web site…
Hi Guys
You can use SIL connectors…but it is easier to use a 1:1 ribbon cable with 3 DIL connectors…please see http://www.midibox.org/forum/index.php?topic=8300.5 , last message in the thread.
Sorry for not linking directly to the message, I’m on the palm and the forum WAP mode only gives a thread url.
Also that explanation is not so great, so let me know if it creates more questions than answers.  :wink:
Best Regards
SmashTV
Can you connect a DOUT from the J2 of a DIN? That would be very tidy.
Mick Berg.
That it would…but no.
The take one and pass it down nature of these serial chains prevents it.  (Unlike IIC where each device has an ID/address)
Best
SmashTV
Ah well.
By the way, Smash, I think you should update your website to reflect Rev.4 of your PCB’s. I was confused for a while, as the documentation refers to Rev.3.
Also, I expect you know this, but the pinouts of the 10-pin input headers on the DIN board are still flopped in Rev. 4, ie 1,0,3,2,5,4,7,6. Your errata should point this out.
Otherwise I’m very happy.
Mick Berg.
Hi Mick
DIN R4 docs are at http://www.avishowtech.com/mbhp/mbhp_dinR4.html
Current docs are always linked from my info page, and I will update the link from the buy page soon.
The flipped connectors are already on the list for future revs. on both the DIN and DOUT.
Best
SmashTV
Hi.
Thanks,
Mick Berg.
I used a double-row header, 10-pin IDC (I found one in an old serial port riser cable). Then I separated each wire and joined both even and odd wires to two separate 5-pin SIL connector. Then, in this Y-shaped cable, I guessed which was the DIN and which was the DOUT :stuck_out_tongue:
Best regards,
Enrico
