Connecting Baseboard to CS
Someone a while back posted pictures of a solution for connecting the MB6582 CS board with the baseboard using pin headers. I can’t find that thread, can anyone help?
Hola,
here´s some pictures of my build:
http://discourse.midibox.org/t/topic/14451
Orange_hand proposes the connectors on the baseboard and it really works well, too. Just make sure that they fit in, because it is quite tight there :slight_smile:
Many greets and have fun building!
Peter
Yesss, that’s exactly what I needed. Thanks so much for documenting!
http://discourse.midibox.org/t/topic/9152
Man…I soldered the 90 degree pin headers to the CS board…all good. But I soldered regular pinheaders to the baseboard, and crimp plugs to both ends of the cables…now I realllly have to squish to get the case closed. I really don’t want to solder anything directly to the board, or even the pins. I’ve only had bad luck with weak wires.
