Connecting a pedal to the AIN
Hi… I’m making a Mb64 and are planning for it to have a pair of 6.3mm (1/4") jacks, so i can connect  control pedals like on a synth.
Can i connect the jacks directly to the AIN module just like pots/sliders, or do i need extra resistors and stuff?
I also plan to connect jacks to the DINX4 (for foot switches) and have the same dilemma about that.
Another question btw:
I thought about connecting the DINX4’s expansion port (J2) to a 9pin D-SUB, so i can connect another DINX4 as a external device (are planning to making a simple keyboard, Kraftwerk style :-). Can i do this, or will i get random MIDI messsages whenever the port is not connected?
/J
if it’s expression pedal (for volume for example) you can plug them with stereo jack on AIN modules, if it’s just a switch pedal, connecet them on a DIN module :wink:
For the external DIN, I think it work if the cable is not too long… (don’t exactly how long it can be)
OK, thanks… i am totally ??? about electronics… =)
see this schematic from Matteo Bosi:
http://www.ucapps.de/midibox_ext/ep/expressionpedal.gif
Best Regards, Thorsten.,
Anyone who knows about that? First one who does gets a dirty swedish joke  ;D
That can be pretty long!! Its just an digital on or off. I would guess at least 5m or more (especially if u you use a shielded cable!).
If you should encounter problems, or want to make it even longer, you can lower the R at the depending pin of the IC, which pulls the pin up to 5V (the original R is 10k I think, so you could go down to 4,7k or so). But I would rather first try it out with the original R, so the IC doesn´t get blown accidentially (although this shouldn´t happen as long as you keep the R above 1k).
Just use a shielded cable and everything should be pretty fine up to 5m or more.
Great, thanks! And as i promised:
http://www.sr.se/p3/rally/sounds/ra9706g2.ram
OK, thnx, although I have *no* idea what this guy is talking about, cause I don´t speak one word swedish…  ;D :wink:
hi !
anybody know if all the expression pedal are built
with 10kOhm potentiometer inside ?
can i buy any model of expression pedal ?
thanks very much.
Hehe, you just have to love this screaming maniac GUNDEMAN :slight_smile:
/Wise (from Sweden…)
i think i haven’t understand  ::slight_smile:
I don’t understand too :wink:
But I think that other value can be used without any trouble. I
thanks  :wink:
