Yes, for your Master Fader, you need an additional core - Do you really need a Master? - Think about it.
Regarding the MF-Boards I would suggest, that you take 2 and the single Master Fader you build just partially on a stripboard.
Regarding the DIN/DOUT boards you see it correct but I don’t feel for counting it through.
Regarding the connection of the units, it depends on your host soft. In Sequoia I would connect the master-unit as an independent unit on its own midi port. If you want to connect it together with an 8-fader unit onto one port and handle it as the “master”-controller, you probably have to make use of MidiBox-Link.
“Regarding the connection of the units, it depends on your host soft. In Sequoia I would connect the master-unit as an independent unit on its own midi port. If you want to connect it together with an 8-fader unit onto one port and handle it as the “master”-controller, you probably have to make use of MidiBox-Link.”
the 5/5 as you use 3 cores and need at least 3 MIDI connections…
good to have 2 reserve for later expansions… or you can use the 4th port for the master fader as suggested by Roger
I will not use a separate master fader as each fader on my master panel can function as the master fader… we all have our own preferences :))))
I have just calculated that I need for all my VU LED panels an separate core and 4xDOUT4… is it possible to use a link or LTC to guide the signal through an another core…???
The gm5 (which is the fun little IC) is always a 5/5. I think you’re referring to the PCB: single IO PCB with the possibility to extend (which is what TK sells) or the gm5x5x5 (which is what I sell).
How can I get this gm5x5x5 pcb? Is it supplied with the GM5 chip?
