I have allso set all other aout options to 0 to not conflict with the options i want to use.
In the ensemble settings ext menu I have set F2A and V2A.
When I measure the output at the AOUT_NG channel 5 and 6 I get a constant 10V. The only way I have been able to change that output is to inverse the signal from the ens->ext menu (setting Iv5 or Iv6).
Isn’t the output supposed to be about 0V then no note is played and 10V when a note is played?
TK: Ah, thanks. That explains it all. I can confirm that the volume setting is propagated even though the response is linear (volume appears very low until settings above 100). I will experiment some with the modulation matrix. I guess it is impossible to get access to the SID chips VCA envelope…
Rosch: I am using 1 AOUT_NG per synth engine to control one SSM2044 board and 1/2 SSM2164 board per synth engine. and can confirm that it works.
